Loop of songs in timeline
mwilkins
Post by mwilkins »
Is it possible to make a sound track continuously play in timeline? Loop is selected but at the end of the track all actions stop.
I would like to be able to have the scenes repeat with the track continuously. Experimenting with a setup for a Halloween event to which a sound track for a haunted house will need to play for several hours.
Thanks,
Re: Loop of songs in timeline
The media file is supposed to loop under Windows, but it effectively does not loop under MacOS.
We are presently not able to fix that issue, which requires quiet a lot of time to go deep inside the MacOS library files.
Sorry for this.
However, please note that, you can play a timeline in loop via a button in Live.
mwilkins
Post by mwilkins »
Thank you.
Will create a button in Live and give it a try.
mwilkins
Post by mwilkins »
Live button did the trick.
Thank you support for your help on such an easy fix that I didn't think about.
Return to “Live - TimeLine”
