6.25 Crashes when turning off solo buttons
shokwaves
Post by shokwaves »
Have just had to go back to 6.24 I installed 6.25 and when I open live the solo buttons, chase play and random play are turned on. As soon as I try to turn them off live crashes.
Any ideas
Running on windows 7
jaxx00974
Re: 6.25 Crashes when turning off solo buttons
Post by jaxx00974 »
Where they 'on' when you backed up you lighting show on 6.24 before importing into 6.25 ? If so try turning them in 6.24 off then export. Load up 6.25 then import and turn them back on, worth a try.
For the record, I am using 6.25 Final and I dont have this problem.
Lee.
We can not reproduce this problem.
You can send your lightshow. We will check it.
For information, there is no need to export/reimport the LightShows data when upgrading the Sofware.
Return to “Buttons”
