V8 - master fader speed control [fixed]
Clgsound
Post by Clgsound »
Was unable to upload a video so I added it on youtube. here is the link. https://www.youtube.com/watch?v=u1K1b4lVxVo
Support,
There is an issue with the master fader speed control. When selecting to move to a new position, the lights will not only increase or decrease their speed, it will move the position of the lights back and forth anywhere between point A and B. This function should only control the "time" of the step, Not the position in which it is coming from or going to. It only does this while in-between positions. Once in final position it won't move anymore when moving fader.
My position scenes have only X/Y activated and set to a Sin wave 5 sec step.
Re: V8 master fader speed control
Please post your lightshow.
We will check that.
Clgsound
Re: V8 - master fader speed control
Post by Clgsound »
How would you like me to send you the show. I exported it but when i go to upload here it says attachment quota has been reached
You can email it to us (viewtopic.php?f=3&t=19).
Please post a new video showing all actions you do after starting the software.
(there should be some other buttons on)
Clgsound
Post by Clgsound »
Yes sorry forgot to mention. I have a master for all my lights on Button #3 they are labeled masters. They will set home position and shutter open and dimmer full. Once those 3 are activated the rest will work. This is my V8 Test show. So its not quite a full show worth but has a little bit of everything to test with.
Sorry but we are not able to reproduce the same situation.
If video is not possible, please send screenshots.
Clgsound
Post by Clgsound »
I will post a video when I get home Sunday. I saw this by (on my show)
1. The 3 master buttons are activated.
2. If you go to positions on apc20 page have them in the up position.
3. Move master fader "position speed" all the way down.
4. Select the button Down on positions page. Nothing will happen because speed slider is down.
5. Slowly move speed fader lights will start to move from up to down slowly. ( never go past 0% when loving fader up)
6. Move fader up and down as I did in video and lights will go back to up position along with fader then down to however far in transition it has gotten.
7. Once in down position it's fine and won't move.
Seems there is more than just speed programmed to the speed control.
Clgsound
Post by Clgsound »
https://youtu.be/vncJ7NGM9Gs
Here is another video from a fresh start showing every step I've used.
My color and Dimmer effects work as should but my position speed and movements. (anything X/Y related) jump and control more than just speed also scrolls through the steps it seems.
We are not able to see that video, because it is a "private video".
Please check the rights to see it.
