Google sketchup
AEW
Google sketchup
Post by AEW »
I think it would be great if I could import a room from Google sketchup :D
Can you arrange that?
Re: Google sketchup
This is not possible for some technical reasons.
However, if you can save as "OBJ" format, you can create 3D objects and use them in 3DView (the 3D objects must be small size files).
Re: Google sketchup
With the "Pro" version of "Google Sketchup", you can export to the ".obj" format, the format used by 3DView :
http://sketchup.google.com/support/bin/ ... swer=36203
tomrbland
Re: Google sketchup
Post by tomrbland »
You can also use http://www.artofillusion.org/ which is free.
Remember to keep your file simple and its size small unless you have a stupidly quick computer!
