Fade option does not work [fixed]
pogjack
Post by pogjack »
Am I missing something here. I just downloaded the 7.1.80 showxpress version on my Windows 2010. I made an easy green led up scene and added the Fade Up and Fade Down option on the button on Live. I made sure the Settings had my desired speed, but it's not working.
I even opened the DMX graph and watched it. Its not working, the DMX channel just full on, full off, there is no fading.
Like I said, I just downloaded that version so no changes on this program.
Thanks,
pogjack
Re: Fade option on Live Button
Post by pogjack »
Ok, just thought of something and I found out the problem. I kept this for others who may have a problem.
If you don't have a fixture assigned to that channel, then the Fade In/ Fade Out Live option doesn't work. Even if you set a scene for it, I'm assuming the program doesn't know what channel to dim (makes sense).
It's exactly the case.
FYI : The dimmed channels are : dimmer;white;amber;red;green;blue;cyan;magenta;yellow;uv;par_can;par_can_blue;par_can_cyan;par_can_green;par_can_orange;par_can_pink;par_can_red;par_can_yellow
FYI #2 : V8 does not allow "not assigned channels".
pogjack
Re: Fade option does not work [fixed]
Post by pogjack »
Hmmm. I do like the unassigned channels because I've ran into a light that I couldn't figure out the brand and needed to move the faders to determine how to make it work.
