ADJ - Inno Roll HP
ineedabeatdj
ADJ - Inno Roll HP
Post by ineedabeatdj »
I'm looking for a profile for the ADJ Inno Roll HP that also works in 3D mode with Gobos if possible. I'm guessing it will have to be built as a scanner to work in 3D. And I know 3D will not give me the same effect as the actual light, but it would be nice to see what colors and gobos are coming from the light. I've attached a pic of the gobos used. If you can't find the gobo images, you can put gobo #1-6 instead for 3d view.
Manual
http://intranet.americandj.com/ItemRela ... oll_hp.pdf
Product Page
http://www.adj.com/inno-roll-hp
Thank you for any help!
Brad
Re: ADJ Inno Roll HP Profile?
Done.
ineedabeatdj
Re: ADJ - Inno Roll HP
Thanks a lot. It works great!
