RGBAW Pixel Fixture
1stKingfish
RGBAW Pixel Fixture
Post by 1stKingfish »
Hi there
I am using a set of eight Longman VPower 903 bars that i wish to use in pixels. These fixtures has three LED blocks, hence 3 pixels. Fixture channels are as follows:
<Channel index="0" name="dimmer" value="0" fade="1"/>
<Channel index="1" name="red" value="0" fade="1"/>
<Channel index="2" name="green" value="0" fade="1"/>
<Channel index="3" name="blue" value="0" fade="1"/>
<Channel index="4" name="amber" value="0" fade="1"/>
<Channel index="5" name="white" value="0" fade="1"/>
<Channel index="6" name="red#2" value="0" fade="1"/>
<Channel index="7" name="green#2" value="0" fade="1"/>
<Channel index="8" name="blue#2" value="0" fade="1"/>
<Channel index="9" name="amber#2" value="0" fade="1"/>
<Channel index="10" name="white#2" value="0" fade="1"/>
<Channel index="11" name="red#3" value="0" fade="1"/>
<Channel index="12" name="green#3" value="0" fade="1"/>
<Channel index="13" name="blue#3" value="0" fade="1"/>
<Channel index="14" name="amber#3" value="0" fade="1"/>
<Channel index="15" name="white#3" value="0" fade="1"/>
<Channel index="16" name="shutter" value="0"/>
<Channel index="17" name="mode" value="0"/>
<Channel index="18" name="color_macro" value="0"/>
<Channel index="19" name="control" value="0"/>
From the above channels one can see this fixtures has a set of three RGBAW pixels. While defining this fixture as a "pixels" fixture i noticed that "pixels" only make provision for RGBWA pixel types.
How can i go about fixing this issue?
Re: RGBAW Pixel Fixture
You can select "RGBWA".
Pixels presently manages only RGB channels.
Return to “Pixels”
