Resetting all midi
jcaniford
Resetting all midi
Post by jcaniford »
Is their a way to reset all the midi channels? IE delete all the ones that have been assigned? I am switching to a new controller and want to just clear all the set midi out to start clean. Possible? other than one at a time?
Re: Resetting all midi
Sorry but this is not possible.
pogjack
Post by pogjack »
I would like to +1 this also including the keyboard triggers.
Reset button
karmaeventlighting
Post by karmaeventlighting »
I would like this as well
Bakenectar
Post by Bakenectar »
Hey so what is the status of this being an option? I have seen it as an option in several other softwares that can use MIDI.
Imagine someone who has a 10+ page show that is all mapped, just a basic redo to even be able to update could take a few hours
Thanks for the help and support!
lse
Post by lse »
The option to reset the midi and triggers is a must need. Nothing worse then chasing down a scene that has the same midi.
Bakenectar
^^^ EXACTLY!! ^^^
Also I liked how a while back you could set multiple buttons/scenes to the same MIDI tigger and now you can not without using a macro which is not preered. Is that something that can be changed back or is doable with the new MIDI functionality just added?
lse wrote:The option to reset the midi and triggers is a must need. Nothing worse then chasing down a scene that has the same midi.
Please note that you now can track this with the function "Export midi triggers" in "Live" => "Buttons" menu.
Bakenectar
A release all MIDI should still be an option as tracking down may be easy but resetting 100+ MIDI commands is pretty time consuming!
