Using sound active mode with steps
create scenes with steps
kwdamp
Post by kwdamp »
Is it possible to use sound active mode, in steps? Assuming of course the specific light has this feature?
For example, for my ADJ mega par profile lights i see Sound active mode 1 and Sound active mode 2 in the programs list. But, it doesnt seem to do anything when I have those selected, even if music is playing.
Does the audio need to be received somewhere else?
Also, how would I know what result to expect? Some programs change colors, others strobe, and yet others do both.
Re: Using sound active mode with steps
"Audio" level is supposed to put the fixture in a standalone mode, running with sound coming from the microphone of the fixture.
In this mode, the software does not control the pan/tilt/color/... of the fixture.
kwdamp
Post by kwdamp »
So it will work with the controller, but it will basically be exactly the same as if I had simply set the pre-programmed sound function on the light?
That's good to know, thanks!
Return to “Editor - Steps”
