[v6.24] Audio in timeline [fixed]
melvar
Post by melvar »
Hi everybody
It's very strange...
I'm creating a timeline with sound, save it, and when i try to open it or to play in live, lights are correctly playing but there is no sound...
Where is my mistake ? Did I forget to activate an option ?
Best regards,
Loïc Gerard
Re: [v6.24] Audio in timeline
Are you able to play the sound file with the Windows Media Player ?
melvar
Post by melvar »
Yes, every audio files are read with Media Player.
My recents investigations showed that the problem has a temporary fix. Indeed, i have just to leave live mode and to reopen it...
I'm having this problem with my two computers, the first one is on Windows XP, the second one on Windows Vista.
Best regards,
Loïc Gerard
Could you tell us if you have to quit/restart application Live, each time you insert a new audio file ?
Or are you able to play all audio files, after you quit/restart application Live only one time ?
melvar
Post by melvar »
It seems this is instable.
Indeed, i encountered this problem only when i open for the first time the live editor for my project. Ever after. But when I create a new project, I often have the same issue. Often, but not every time...
I also point out another problem in live editor :
When i delete a page, if there is no other page, it's impossible to create another page. Indeed, when i right clic on combo, Sweetlight is crashing.
jaxx00974
Post by jaxx00974 »
Worth noting from my own experience. I also had similar problems before and could only resolve it when I had Windows media player open on the task bar, then evrything in Sweetlight would work,, , The only time this didnt happen is when I did a fresh install of Windows and didnt install any codecs, then Sweetlight workes fine. This led me to believe it was to do with the audio codecs. For the record, I was able to install the Fraunhoffer MP3 codec without it causing any problems.
Thought it might help your situation.
Lee.
- audio problem
We just added this topic: viewtopic.php?f=31&t=393
- "delete page" problem
This is a bug.
Working on it.
melvar
Post by melvar »
Thanks for your help !
"delete page" problem is fixed in the beta software: viewtopic.php?f=42&t=398
melvar
Re: [v6.24] Audio in timeline [fixed]
Post by melvar »
Thanks for your reactivity !
It's really great !
Return to “TimeLine”
