Is it possible to do the opposite movement ? [fixed]
adamgeorge
Post by adamgeorge »
Is there anyway that I can make my fixtures do exactly the opposite movement in generator
Re: Generator
Right click in the curve display, and select "Reverse points order" in the popup menu.
adamgeorge
Re: Is it possible to do the opposite movement ? [fixed]
I see it in the menu bar but it is greyed out. Do you know why?
This function is available only for pan/tilt and RGB curves.
