MAX FPS
gilsontech
MAX FPS
Post by gilsontech »
While testing the hardware/software we're seeing a max, but consistent 20fps output of DMX.
2 Questions:
1 - Is this a software or hardware limitation? Can it be speed-up to at least 30fps? Ideally 44fps?
2 - What is the fps for Artnet through the software?
Thank you.
Working on the next BIG thing
Re: MAX FPS
It was an "Operating System" limitation, when we made V6 & V7.
It is not easy to make faster with a multi-OS code, using native OS gadgets.
This means Artnet is not faster.
We keep in mind to make new tests with V8, which has a new "scene/project" player engine.
BTW, could you please tell us more about the weakness of 20fps only ?
gilsontech
Re: MAX FPS
We do a lot of pixel effects over a lot of channels at once and we get slow frames, glitchy signals and it would be great to see faster speeds and fps.
Looking forward to v8
Re: MAX FPS
In V7, the Pixels projects are converted to scenes, and the scenes are played in Live.
In V8, Live will straight play the Pixels projects ; the rendering will be better, even with same speed refresh.
