"reverse tilt" reverses pan instead of tilt [fixed]
kcampb8965
Post by kcampb8965 »
I seem remember in an earlier version of Show Xpress, having the ability to reverse pan/tilt in the 3D view. My Chauvet scanners are behaving opposite that they do live. Was I mistaken and if not, is there a way to reverse the controls in Ver 7.1.32?
Re: Change pan/tilt in 3D view only
Edit the fixture in Editor > Fixtures, and in the section "3DView" of the window "Edit fixture", you will find two checkboxes "reverse pan/tilt".
kcampb8965
Thanks,
Unfortunately, the editor lets me change the pan but not the tilt. The fixture is a Chauvet Intimidator Scn LD 300 in 11 Channel mode. Any idea why it lets me reverse the pan and not the tilt?
We double-checked and we found a bug ("reverse tilt" reverses pan instead of tilt).
We will publish a fixed executale file, as soon as possible.
We will keep you informed.
kcampb8965
kcampb8965
Re: "reverse tilt" reverses pan instead of tilt [fixed]
Thanks for the quick response. When I try to run the .exe file, I get an Error: library 'efk_hardware' not found! Any advice? Should I uninstall my existing software before installing this version?
Please read this: viewtopic.php?f=3&t=3438
kcampb8965
That worked. Thanks!!
