ADJ mega bar 50s - beam is always flashing [fixed]
punkkipper
Post by punkkipper »
Hey,
I'm using some ADJ mega bar 50s and although the software controls the lights properly in real life, it won't hold a steady beam in the visualizer. The beam always is flashing---as if there is some sort of strobe feature turned on (which there isn't).
any thoughts?
thanks
Re: ADJ mega bar 50s - beam is always flashing [moved]
We do not find the "ADJ mega bar 50s" in our software.
Please tell us where to find it.
punkkipper
The ADJ Mega Bar 50 is the "half size" of the ADJ Mega bar---this is the same as how the Chauvet Colorstrip Mini is the "half size" of the Colorstrip. I used the regular ADJ Mega Bar profile because I figured it was the same thing---only half the length. The software seems to be control the lights correctly in real life (I could be wrong...it might be missing something)...but the 3D visualizer constantly flashes the light...even with the "strobe" fader all the way down.
The personality files contain errors.
Here are the fixed personality files.
Here is the reason of "always flashing beam": viewtopic.php?f=13&t=372
