I have configured the Sweet Light Program with a spotlight Cameo with both, 4 addresses DMX and 6 addresses DMX, and it has worked very well during almost 2 days. But now when I send the signal to activate the green colour it doesn't work.
I have tried with diferent spotlights, with different models and it will always do the same.
I have also reinstalled the programme but I haven't solved it.
Could someone help me with this issue?
Thank you very much!
Problems with the "green address" [fixed]
Re: Problems with the GREEN ADDRESS
Try a different dmx adress. Increase it by one and test it again, is there still the same problem?
Are really all the other channels working (strobe, function etc)? If yes, the fixtures are defenetly broken.
FYI: You do not have to configure all lights in setup for this test because the software also sends Dmx for unconfigured channels.
Greetings from Germany!
Now run perfect!
THANKS!!!
THANKS!!!
