[request] More points in generator [done]
vvmke
Post by vvmke »
Please make the maximum number of points in the generator more than 10! Preferably unlimited or only limited by your computers RAM... Also, It would be very helpful to have more control over points with an adjustable direction point/line like the pen tool has in adobe illustrator. example: https://helpx.adobe.com/photoshop/using ... paths.html
It would also be EXTREMELY helpful to have the ability to select all points with a command like CMD+A and have a lasso that lets you select multiple points at one time or just select multiple points by holding shift.
Time is money and these things would really make a difference!
One more thing that could be helpful is to be able to select multiple channels and see them all layered over each other. for example, you could view the X and Y value path and at the same time see the dimmer path in another color. This way you would be able to easily synchronize your movement and dimmer chases.
Thanks!
Re: REQUEST! More points in generator! And more control...
In V7.1.50, the max points in Generator is now 100.
viewtopic.php?f=2&t=3500#p14412
Lighter007
Post by Lighter007 »
WOW nice :)
thanks
Greetings from Germany! :)
