Fixture with two beams - Prism effect
elev8d
Post by elev8d »
I'm using 2 ADJ Vizi Spots, 2 ADJ Reflex LEDs, 1 ADJ H2O, and 1 Ultratech Radiance Hazer.
I'm using the Remote DMX box with a Snow Leopard Mac.
The hazer is working brilliantly so far with the ShowExpress 6
On the other hand the other lights are working somewhat satisfactorily.
As I mentioned in another post it doesn't work well with the reflex LED scanner because the light has two beams moving on independent pan settings.
For the Vizi Spot the 5 facet and infinite prisms don't show up in the 3D visualizer properly.
I'm also running into motor issues panning issues with my Vizi Spots which weren't occurring before when I using the cheaper but not as complete ADJ MyDMX.
Re: My lighting setup
Pan/Tilt functions of Editor and Generator are not able to manage a fixture with one tilt channel and two pan channels. The lonely solution is to use the faders in Editor.
Current 3DView application is not able to show prism effect.
Return to “Setup”
