Some columns, in a page, do not have any buttons [fixed]
kcampb8965
Post by kcampb8965 »
For some reason, new buttons I add to a page are a different size than the rest. I have 18 columns of 6 buttons each. As I add new columns of 6 buttons, they are smaller and don't fill the screen as the other columns do. Is there a setting that may be causing this?
Re: Button Size
Please post (or email) your lightshow.
We will check that.
kcampb8965
Re: Button Size
I'm sorry I have not replied sooner. The Holidays have me scrambling.
There are several folders and files associated with this light show. Which file do I attach?
Re: Button Size
Please post first only the lightshow folder.
We will see later if we need some other files.
kcampb8965
Re: Button Size
I'm sorry...excuse my ignorance, but I must be a little behind the curve here....how do I post an entire folder? I can upload one file at a time, but I can't select the entire folder for upload with your utility. Please walk me through posting an entire folder.
Re: Button Size
Please read this: viewtopic.php?f=3&t=168
kcampb8965
Re: Button Size
Thanks...I didn't realize I could export the show....my problem now is the program crashes every time I try to use that utility. I'm not having much luck here. It will suck big time if I have to start from scratch. Let me try to zip it with the Windows Utility and attach it...
OK..that didn't work...the file is still 290kb...now what??
kcampb8965
Re: Button Size
You can retrieve the folder at this Dropbox link:
https://www.dropbox.com/sh/ok3ggi9jpg7k ... VXxra?dl=0
Re: Button Size
1. for an unknown reason, your lightshow is corrupted. There is an infinite number of folders "Ready Room"(..\LightShows\Ready Room\Ready Room\Ready Room\Ready Room\Ready Room\Ready Room\Ready Room\...).
2. for an unknown reason to, in the "ini" file of Live, some buttons have wrong line&column numbers.
We manually fixed the INI file, and we removed the extra "Ready Room" folders.
Here is the fixed lightshow.
kcampb8965
Re: Some columns, in a page, do not have any buttons
Thanks,
The extra columns are gone, but the button sizes are still mismatched. Look at the attached screen capture. All columns (except the last 2) have 6 buttons each. The last 3 columns of 6 have smaller buttons so things don't line up the way you would expect. Of course I haven't changed the color on those buttons yet, but it's important that everything is the same size and lines up. What may be causing this?
Return to “Buttons”
