Unable to assign MIDI to master faders [fixed]
chibbert
Post by chibbert »
Hello -
I am using v7.1.12 on the Mac (Yosemite).
I am able to assign MIDI commands to buttons in Live as normal, but the "Learn" command does NOT function in Settings for any Master Faders (or anything else on the Settings panel, for that matter -- Pause, Freeze, etc).
Can you verify this bug? Thanks!
Re: Bug - Unable to assign MIDI to master faders!
Yes, this is a known bug of v7.1.12.
The fix is here: http://download.thelightingcontroller.c ... roller.zip
chibbert
Post by chibbert »
Thank you! Seems to fix the problem. Much appreciated!
lse
Re: Unable to assign MIDI to master faders [fixed]
Post by lse »
i have the same problem and the link is not working. i am running show on a pc with windows 7
aurasystems
Post by aurasystems »
I have recently downloaded the new Version 7.1.23. The Midi shortcuts Pause and Freeze seem to work but none of the other shortcuts are working, ex. Master Fader 1-4 and BPM/Drum. Is anyone else having this problem? Perhaps I am not applying these shortcuts to the right kind of scene. Could someone shed light on this?
