BUG with faders and MIDI controller (and a solution...)
zkflow
Post by zkflow »
Well... i had this problem since the first V7...
when i link faders (physical) to showxpress (master fades) and then i do a little test... THE PROGRAM FREEZES... i tested using a nanokontrol, AKAI, also VIRTUAL MIDI CONTROLLERS (with Ableton and FL Studio) and the same thing... when i do some FAST movements the program freezes... its this normal?
Now, a solution that worked for me: RUN Showxpress As Administrator...
zkflow
Re: BUG with faders and MIDI controller (and a solution...)
Post by zkflow »
Running as admin.... stills freazing...
please help!! i need to use physical faders!!!!
Earl Harvey
Post by Earl Harvey »
New update for that....
viewtopic.php?f=2&t=3266
zkflow
Post by zkflow »
I'm using the new version and the BUG stills there
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: TheLightingController.exe
Application Version: 0.0.0.0
Application Timestamp: 5421a548
Hang Signature: dc0f
Hang Type: 517
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2058
Additional Hang Signature 1: dc0f0770ca1c2ed3627493e21e830377
Additional Hang Signature 2: 7111
Additional Hang Signature 3: 7111a0e29ce657798509b96777f6e312
Additional Hang Signature 4: dc0f
Additional Hang Signature 5: dc0f0770ca1c2ed3627493e21e830377
Additional Hang Signature 6: 7111
Additional Hang Signature 7: 7111a0e29ce657798509b96777f6e312
zkflow
Post by zkflow »
***TEMPORAL SOLUTION***
Link the fader to the DMX Dimmer channels of the fixture using to "PATCH MIDI TO DMX" Function (in the general options)
and with this bug... the master faders are useless :( very bad
Can you please run again the version 6, and confirm that, the same lightshow with the same midi device and the same computer work correctly ?
zkflow
Post by zkflow »
i'm going to use another computer today... and i'm going to download V6 and the last V7 to confirm...
zkflow
Post by zkflow »
some specs about the computer were i found this bug:
Windows 7 Ultimate 64x
Intel i5
8GB Ram
