Beam disappears at some distance [fixed]
Lighter007
Post by Lighter007 »
I noticed that several times: At some distance the "reflection" of the objects is not visible anymore (-> when the fixture is "too far away" from the wall/object). It is a pity beacause this doesn´t look very nice :( Is this a technical problem or beacuse of rendering time or something? May this be fixed, please?
Regards,
Lighter007
Greetings from Germany! :)
Re: Beam disapperas at some distance
What is the size of your stage ?
Lighter007
Stage is very huge. But fixture is not so far away.. attached a image.
audiopyle
Post by audiopyle »
I also have a problem with this. It appears that the default distance limitation of the objects in the 3D View is under 80 feet. I am trying to put spots on a wall from a distance of ~ 100' and the beam cuts off short.
Lighter007
Will there be any change available soon?
Lighter007
Re: Beam disappears at some distance [fixed]
Working perfectly :) thx
