Intial Observation
Intial Observation
Post by Pink LD »
All week, this tour, 3D has been showing a light on though there is no data being sent. When I try to find what data has that par on in 3D I can't find anything causing it.
However I did find that 3D was shifted in what is was doing versus Live, and actually looking at the rig.
Live and the rig were completely correct, but 3D is wonked out along with an erroneous light on at all times no matter what I do.
Re: Intial Observation
Noted.
Weird because 3DView is same than in V6, and 3DView management is supposed to have same source code than in V6.
Post by Pink LD »
I have had a problem like this several times throughout the years and each time you sorted it out.
Do you need more info? Do you need me to send you my lightshow?
Lighter007
Post by Lighter007 »
What happens after a restart of 3D View/hole Software? No change?
Greetings from Germany! :)
Post by Pink LD »
No change, problem on multiple PCs. 3D opens with I think it is channel 505 on. Plus my two performer spot movers in the 400s react incorrectly in 3D but are correct in Live.
Post by Pink LD »
It does not matter which of the 5 machines I am on from XP-Win 8.1
Nor does it matter if it is V7.1.5 or V7.1.7.
What does make a difference is which lightshow I use. My archived lightshow from a few weeks ago is fine. But my current lightshow is that problem. But I don't know where and why that is.
