Fader Buttons in Showxpress 7.1
julicny
Post by julicny »
Question -
I have 5 "master fader" buttons in Showxpress that previously had a "bar" that you could move left/right to fade higher or lower. Upgraded to 7.1 and it isn't there anymore, even when clicked to enable.
Answers?
Re: Fader Buttons in Showxpress 7.1
May be a problem of screen resolution (?)
Can you please try with a "big" screen ?
Please note also that V7 use a new "slider" gadget in the buttons, which does not show any cursor.
You can click and drag anywhere within the black area.
gregsound1
Post by gregsound1 »
How do I user the fader button function? I called chauvet and they were zero help. Intuitively I feel like it should fade whatever fixture the button is assigned to. However, it does not work that way for me. I'm using 7.1 on Mac.
It fades from the first to the last step of the scene. This means:
- there must be min two steps
- the middle steps are ignored
FYI, there is a "Fader button", in the demo_show.
gregsound1
Thanks so much!
ddpayton3587
Post by ddpayton3587 »
hi at church we have used showxpress 6.1 now want to upgrade to 7.1 notice the fader buttons. We only have 24 color led at present all other lights are parcan single channel. When I tried to edit faders to fade all I see and can add are the LED.
The Master Faders can drive exclusively the following "dimming" channels: red, green, blue, cyan,magenta, yellow, dimmer, uv, white, amber.
