media button off
pogjack
media button off
Post by pogjack »
How do I make my media button (say a Rim Shot) turn off when its completed (about 5 seconds long). When I push it, I have to remember to push it again to turn it off so that I can use it again. I would like for it to turn off by itself and the "no Loop" option didn't do it.
Re: media button off
Post by Pink LD »
(Comment removed)
Earl Harvey
Post by Earl Harvey »
Your media (MIDI) button is transmitting a momentary note on/off, it needs to transmit as a toggle note on/off or visa versa...if its a drum machine your using to trigger it may not be able to change... Drum samples or sounds usually need a momentary note on/off to be triggered correctly...
@pogjack : For now, media buttons are not able to detect when player finished
We will check if we can improve this.
Noted in ToDo list.
big.ratty
Post by big.ratty »
Hey if I understand your issue try making the like button a flash key
