SlimPar 64 8 Channel 3D Not Strobing [fixed]
udjrentals
Post by udjrentals »
New to Showxpress, however not new to dmx/lighting. I have everything working great in 3D view but the strobing effect for my 30 SlimPar 64 RGBA in 8 channel mode. I've tried just about every setting and searched for an updated profile with no luck. any one know what I could be missing? I have some older 7 channel RGB Slimpars working just fine on all channel in 3D view.
- D512 Plus
- Wireless Trans/Rec'ers
- DMX Cabling
- Windows Visa/Dell Laptop
Re: SlimPar 64 8 Channel 3D Not Strobing
Please post (or email us) the personality file.
We will check it.
udjrentals
Here is the supplied profile I'm using with that came with Showxpress. The Macro's don't work as well in 3D nor on physical light.
ViewType = VIEW_TYPE_COLOR_CHANGER
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 120
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 0
2DViewImage = Chauvet/SlimPAR 64.png
Channel = red
Red,0,255
Channel = green
Green,0,255
Channel = blue
Blue,0,255
Channel = color_macro
off,0,7 new_level,8,15 new_level,16,23 new_level,24,31 new_level,32,39 new_level,40,47 new_level,48,55 new_level,56,63 new_level,64,64 new_level,65,71 new_level,72,79 new_level,80,87 new_level,88,95 new_level,96,103 new_level,104,111 new_level,112,119 new_level,120,127 new_level,128,135 new_level,136,143 new_level,144,151 new_level,152,159 new_level,160,167 new_level,168,175 new_level,176,183 new_level,184,191 new_level,192,199 new_level,200,207 new_level,208,215 new_level,216,223 new_level,224,231 new_level,232,239 new_level,240,247 new_level,248,255
Channel = shutter
open,0,15 strobe,16,255
Channel = mode
RGB,0,31 pulse_effect_0%-100%,32,63 pulse_effect_100%-0%,64,95 pulse_effect_100%-0%-100%,96,127 auto_snap_transition,128,159 auto_snap_transition(3colors),160,191 auto_snap_transition(7colors),192,223 sound_triggering_mode,224,255
Channel = dimmer
dimmer,0,255
This profile has 7 channels, and you said it should have 8 channels.
Please post a link to download the manuel.
We will check this.
udjrentals
So sorry, I posted the incorrect profile.
Filename: SlimPAR 64 RGBA (8CH).txt
ViewType = VIEW_TYPE_PAR_CAN
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
ViewColor = 16777215
2DViewImage = Chauvet/SlimPAR 64 RGBA.png
Channel = red
Channel = green
Channel = blue
Channel = amber
Channel = speed_control
Channel = mode
RGBA mode,0,31 Pulse effect 0~100%,32,63 Pulse effect 100%~0,64,95 Pulse effect 100%~0~100%,96,127 Auto fade transition,128,159 Auto snap transition (4 colors),160,191 Auto snap transition (15 colors),192,223 Sound-active mode,224,255
Channel = dimmer
dimmer,0,255
The two last lines :
Channel = dimmer
dimmer,0,255
must be replaced by something like ::
Channel = shutter
(not sure for values 15 and 16 ; we need the PDF manual)
udjrentals
Re: SlimPar 64 8 Channel 3D Not Strobing [fixed]
Okay, I found the problem. It was on channel 6 that needed to change
To:
Channel = shutter
no_function,0,15,strobe,16,255
One would figure Chauvet would have the correct profile with the software. Now it's getting the Modes and Color macros to work.
Manual located here: http://www.chauvetlighting.com/products ... ev1_WO.pdf
Thanks for the help!
Thank you for the report.
We will correct the profile in the software.
Allan
Post by Allan »
Hi Udjrentals,
Thanks for the information. I will have it fixed and part of the next software release.
Allan Reiss
Senior Product Manager
CHAUVET DJ
