In a previous version it was suggested to have the above switch should remember which groups should be "on" or "off".
It was easy to see this in the versions 6, but with the new icon it does not.
It play havoc on some scene creations when it always reverts to "on".
Is there any solution for this.
John
Group Actions - remember last state
Re: Group Actions
Sorry but we do not understand.
Can you please send some screenshots !
JohnRichards
Re: Group Actions
I do not think a screen shot is going to help.
My problem is if I group 4 moving heads in say a group called "stage heads" and then call that group to program a scene, the default setting for the "group actions" is on. (ie - if I change the X value, all 4 X values change). If I then click the icon to disable the "group action" I can do what I want. If I return back to the scene, the "group action" has again defaulted to on, and if I change 1 X value. they all change.
My suggestion is that in the groups.ini file could a parameter be included that states Action = On/Off
Hope this explains it.
John
John
Re: Group Actions
Yes, this is more clear.
If we save the last state you chose, will this be ok for you ?
JohnRichards
Re: Group Actions
The last state will be fine, and even better if the last state of each group independantly, as certain groups are great with the grouped action set to on. (ie - bar of led parcans used as washes).
John
John
Re: Group Actions - remember last state
would be very convenient
