DMX 400 or so [fixed]
directsound
Post by directsound »
Im having issues with a few lights in the 3d area when Im turning on one light a different light is comming on around the 400 = 430 ch range or so I cant seem to figuar it out my show is atached
thanks MM
Thanks,
From DJ Mikey Mike
http://www.directsound.com
Re: DMX 400 or so
It looks effectively like something is wrong around channel 400.
It might take some days to fix that problem.
directsound
Re: DMX 400 or so
I think the dmx output works ok but I cant remember if I used thes lights with 6.22 but I think I did I just never looked at the 3d viewer as I just used them live
also there is a accu spot that is in the 3d room that I cant get rid of and it is not in my lights list I think it is #4
thanks for your time ...I have a Big Show on Friday if you get a fix can you shoot me a quick email as I dont want to miss it if it is fixed
thank
you
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
Re: DMX 400 or so
Friday (tomorrow) will be too short to fix that problem (sorry for this).
The most important is dmx out is ok.
We hope to be able to send a fix on Monday (this is a big show).
directsound
Re: DMX 400 or so
Ok my show on Friday I was having DMX issues out around the 400 range I couldnt tell if it was a cabling issue or if it was a software issue Please go through the chanels and verify the in and out to the floor and the 3d room thank you for your time and Please let me knowwhat you find as Im not sure where to trouble starting should begian
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
marco
Re: DMX 400 or so
Post by marco »
to Mike
can this be the problem? i found this remark on wikipedia.
DMX512 is a bus network no more than 1200 meters long, with not more than 32 devices on a single bus. If more than 32 devices need to communicate, the network can be expanded across parallel buses using DMX splitters. Network wiring consists of a shielded twisted pair, with a characteristic impedance of 120 Ohms, with a termination resistor at the end of the cable furthest from the controller to absorb signal reflections.
grtz Marco
directsound
Re: DMX 400 or so
nO THATS NOT IT I use a DMX splitter and this issue was internal to the program this time...Also I was only at about 25 fixtures at that run
but thanks for looking out
Thanks,
From DJ Mikey Mike
directsound
Re: DMX 400 or so
Any luck? I have a gig on Saturday thanks
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
Re: DMX 400 or so
For an unknown reason, the file which contains the dmx addressing list ("fixtures.ini", generated by application Setup) is corrupted.
Please replace the file "home_directory\TheLightingController\LightShows\YourShow\fixtures.ini" by the attached file. This should fix your problem.
Now, our problem is we are not able to generate again such corrupted file, using application Setup. So this problem can happen again.
Please let us know if you edited/modified manually this file.
If not, if you made any special actions in application Setup, please let us know.
directsound
Re: DMX 400 or so
Thank you for the fix ...I still have a small issue I have a light in the 3d room that I cant get to go away no mater what I try its called accu sopt#4 the accusopt#4works fine but the one with the space is not in my show or dmx fixture list how do I delete it ?
thanks
MM
Thanks,
From DJ Mikey Mike
