Is it possible to import new 3d objects?
Posted: 11 March 2014, 04:18
by chibbert
Is there any means to bring new 3d objects onto the stage?
Re: Is it possible to import new 3d objects?
Posted: 11 March 2014, 06:28
There are some infos about this, in the below posts in 3DView section.
Posted: 11 March 2014, 18:41
by Lighter007
Posted: 12 March 2014, 00:30
by chibbert
Great. Experimenting shows that it's possible to add anything in the OBJ format. Thank you!
Posted: 19 July 2014, 22:36
by raverezra
So here is my contribution to the form. I've been using google sketchup to create object and export them to a *.obj file. Then I put the obj file in the 3D visualizer object directory. I then can add them in the 3d Vis as 3D objects.
Posted: 21 July 2014, 16:13
Thank you for this feedback.
Posted: 23 July 2014, 15:18
by Lighter007
Yes, raverezra, youre right.
You just had to experiment a bit with the size of the object, for me it was very small as first and VERY huge the second try
But after some experimenting it was perfect.
Lighter007
