Is it possible to import new 3d objects?
chibbert
Post by chibbert »
Is there any means to bring new 3d objects onto the stage?
Re: Is it possible to import new 3d objects?
There are some infos about this, in the below posts in 3DView section.
Lighter007
Post by Lighter007 »
Greetings from Germany! :)
chibbert
Post by chibbert »
Great. Experimenting shows that it's possible to add anything in the OBJ format. Thank you!
raverezra
Post by raverezra »
So here is my contribution to the form. I've been using google sketchup to create object and export them to a *.obj file. Then I put the obj file in the 3D visualizer object directory. I then can add them in the 3d Vis as 3D objects.
Thank you for this feedback.
Lighter007
Yes, raverezra, youre right.
You just had to experiment a bit with the size of the object, for me it was very small as first and VERY huge the second try :mrgreen:
But after some experimenting it was perfect.
Lighter007
