"Timeline" buttons do not trigger the timelines [fixed]
57junior
Post by 57junior »
Hey guys, I have showxpress, and i bought this software planning to midi trigger timelines from logic (we run tracks) with my band. The idea was that i could do all the programming at home and then we wouldnt need our FOH guy to also do lights. the solution i found to this was making timeline buttons for every song and then midi triggering those buttons. The problem is that even though the timeline works great in the time line window, when you make a button it doesnt load anything. when i first started programming they worked fine, then one moment it just stopped and i've deleted the program several times and re downloaded it. this makes my idea impossible. So i need to figure out why and fix it.
Re: Timeline buttons arent doing anything
Please load the "demo_show" (viewtopic.php?f=3&t=114), and check in Live if the button "demo" triggers the timeline. If yes, you can compare with your lightshow.
By the way, please check where is saved your timeline (by default, it should be stored in folder "YourLightShow/Pixels/Projects/".
57junior
Post by 57junior »
thanks! i looked at the demo show and tried to open one of my made timelines in it and it didnt work... then i realized that i had made subfolders for the timelines. i moved them out of the subfolders and now they work. so thats a relief.
Re: "Timeline" buttons do not trigger the timelines [fixed]
Goods news.
In the meantime, we take note of this problem with "subfolder".
Return to “Buttons”
