Hello
I created my own ADJ QA5 profile, 6 channel
R
G
B
A
Dimmer
Strobe
The strobe setup should be values: When I assign the traits to the fixture, I picked STROBE SPEED, then under strobe speed values are 1-15 is No Function, 16-255 is speed. Issue is that in 3D view, this doesn't reflect the actual light function. RGBA works, RGBA dimmer works, but the light strobes and the strobe speed fader acts only as that, speed. There is no ZERO speed.
What do I select in the setup in order to create a proper 3D view resemblance of the light fixture?
QA5 Profile - how to set up "strobe" ? [fixed]
RoyalJenner
Re: QA5 Profile ??
Channel #6 must be "shutter", with the following levels:
- 0 to 0 - "open"
- 16 to 255 "strobe"
(like in the lightshow "demo_show")
- 0 to 0 - "open"
