LEDPAR 56-24 (7CH) is always strobing [fixed]
MH-Dennis
Post by MH-Dennis »
I want to control 8 LED Par56 (7 ch) fixtures from Chauvet. When I try
to create my setup in 3Dview, my PAR56 only strobe. When I load 3 ch
PARs, they work fine, and I get a good static beam, but when I want to
control a 7 ch PAR all it does is strobe.
Note: I've only tried Chauvet LEDPAR56 and LEDRAIN fixtures, but its
the same problem.
Any help would be appreciated.
Thanks in advance,
Dennis
tomrbland
Re: [6.2] 7ch LED PAR56
Post by tomrbland »
Yes I see your problem.
If you edit your fixture and rename the channel "strobe speed" to "shutter" by right clicking the channel "strobe speed" and choosing shutter from the list (3rd list I think?)
you can then change the levels within this new "shutter" channel. right click the one that says "no function" (it has a red cross) and change it to open. change the next one to strobe.
Alternatively I can email you the profile that works if you would like?
Re: [6.20] LEDPAR 56-24 (7CH) is always strobing
Yes, the personality file has some errors:
- the channel "strobe_speed" must be changed by channel "shutter".
- and it must contain the 2 following levels: "open" and "strobe".
Here is the fixed personality file.
[deleted]
