[V6.33] Macros
Shakes
[V6.33] Macros
Post by Shakes »
I have a series of macros where some use moving heads and others don't. On those that don't, the heads may stay in the same position but the dimmer is at zero.
While on a macro that uses the heads, I manually overide the dimmer and fade to 0. I then select a macro that doesn't use the heads but the lamps are on!
I've tried updating the macros with the dimmers at zero but the problem remains. This didn't occur on the previous version and I'm not sure it happened on the beta version either.
Help Please
Cheers
Re: 6.33 Macros
Can you please post the smallest possible lightshow showing this problem ?
Re: 6.33 Macros
We tried with:
- click "songs 1 > Jungle"
- press key "q"
- click "songs 1 > verse #1"
But we were not able to reproduce this problem (the heads beams stay off).
Re: 6.33 Macros
We found something wrong in the code, with some links to this problem.
Please try the following fix: http://download.thelightingcontroller.c ... fix_files/
And let us know if it fixes the problem.
Shakes
Re: [V6.33] Macros
Post by Shakes »
Sorry support - No change.
Shakes
Re: [V6.33] Macros
Post by Shakes »
Any ideas support? :?:
Re: [V6.33] Macros
No.
Shakes
Re: [V6.33] Macros
Post by Shakes »
This problem is showing on 2 seperate laptops. 1 running Windows XP, the other running Windows Vista.
I've just done a reinstall of the software on the Vista m/c and still no change. :(
Shakes
Re: [V6.33] Macros
Post by Shakes »
Support. I've still got this macro issue.
I'm looking for the 6.332 update for live but can't find it. Can you point me in the right direction please?
Currently running:-
Control Board - 6.331
Live - 2.22.4 - 130408
Re: [V6.33] Macros
Official version is now 6.332.
You have to re-install the official version.
But this will not change your problem with the macro. The difference between 6.331 and 6.332 is only a bug fixed in Pixels.
Return to “Buttons”
