Pan tilt movement angle
MickeyMick
Post by MickeyMick »
Hi guys,
Is it possible to change your angle/degree for pan tilt? cause with me it doenst work.
My scanner doesnt react on the new angle degree values.
I need this option so that my circle movent doenst hit the sealing
Re: Pan tilt movement angle
We just checked ; it works here.
PS: this parameter is exclusively for 3DView.
MickeyMick
ah, oke.
I thought it would be a variabel for my scanner too :).
How can i change this for my scanner. the beam now reaches its own(self) fixture :O
It looks like a fixture hardware problem !
MickeyMick
Can it not be fixed by software?
Sorry, but our software is not able to fix this problem.
Randomseed
Post by Randomseed »
Some yokes have movement degree range settings (Chauvet LED XXX spots for example). If you have that its very useful for create a more usable movement range.
In software I would think they just need to add the ability to restrict a channels value to a user defined range of values (say over 100 but under 200) so the slider values could never go outside that range and restricting the range.
Return to “Setup”
