Feature Request: one single screen for all button options
Post by Pink LD »
Support:I just put a couple of buttons on a Live page, then moved them, gave the m a colour, made them a Flash button, changed their speed, gave them a trigger and gave them a fade out
That's when it occured to me that I had to right click a menu for each of these actions. Would it be feasible to just have one screen for all these, and more, of these button modifications?
Like I right click the button and the menu gives me all those type actions in one screen?
Like the menu has the button name, go to editor file and the 3rd choice would be "Bottom Modifications" And on that screen do everything in one place? I could make it a Pause, fade up, Prest, red colour button and move it?
Or rename it, give it a trigger, set the speed, make it no loop and assign an image to it?
Re: Feature Request
Your request makes sence.
The "one line per option" menu was ok one year ago, when there was only a couple of options.
Now the menu is 20 lines long, which looks effectively a bit long.
We add this request in the TODO list. We can not give a date because such job is pretty long and not essential.
Re: Feature Request
Post by Pink LD »
I understand. Yeah that menu sure grew in a year. Thanks!
Re: Feature Request: one single screen for all button options
Post by Pink LD »
Ultimately if we went that route I expect I would ask next if a Macro would be able to recall all those settings like you did for me with Presets. So I guess I ought to throw that consideration in the ring as well.
It makes sence to.
"Macro should memorize all buttons options" is added in the TODO list.
Post by Pink LD »
Looks good. Thanks.
Andreas
Post by Andreas »
Why not make a "Edit" button for all Pages in Live?
When you push the Edit button you get a list with buttons with all the functions under right click.
And if you could fix that you could move a button by just drag it instead of like now you have to push the arrows to move it. This would be able in Edit mode.
Maybe it will be a problem when you want to edit a page while doing light live, I don't know.
Post by Pink LD »
I know I would love to just drag a button to move it and create a new column to place it, at times.
"Edit button" is in the TODO list.
"Drag and drop" is not easy, when it has to be multi-platforms.
Return to “Buttons”
