Can you make a channel default to disabled? [fixed]
create lighting scenes
mark1542
Post by mark1542 »
We have some house lights that are typically never used since we already have scenes set up to turn those off and on. Is there a setting that would allow those channels to automatically be set to disabled so we don't have to manually do that each time we create a new scene?
I thought about making a "default" scene we could start from that has all channels disabled, then just using that as a template to work from whenI build a new scene, but I didn't know if there was a setting that would allow the same thing.
Thanks!
Re: Can you make a channel default to disabled?
When a scene called "default" is existing, the "new scene" menu loads this scene.
When there is no scene called "default", the "new scene" menu sets all channels to state "disable".
mark1542
Post by mark1542 »
Aha! That was exactly the problem. Somebody must have gone in before me and edited the "default" scene. I set all channels to disabled on that, and now when I create new all channels are disabled.
Thank you!!
Return to “Editor”
