Button triggers lost after reboot
MagicManiac
Post by MagicManiac »
I am using Sweetlight software (v6.30) in combination with a SSA interface. The DMX input is conneted to a showtec SC2412.
The SC2412 is used for hardware triggers. I'm using Live with 4 panels with 7 triggers in total. When I reboot my system I lose all my DMX triggers. On the live screen I see all the triggers but when I use that DMX channel nothing happens.
I tried keyboard triggers, these triggers all work after reboot of the system, so no problems there.
How can I solve this problem????
Re: Button triggers lost after reboot
First it works, and after Operating System reboot, it does not work anymore !
What do you have to do, to make these dmx input triggers working again ?
MagicManiac
When I rightclick on the button and select the trigger option. I see the DMX trigger, for instance channel 16. Then I change the trigger to another channel like 48 or 212 (doesn't really matter). I save that setting. Then open the trigger again and change it back to 16 and save again. After that everything works again.
For the keyboard triggers I don't have to do that.
Return to “Buttons”
