Print Grit layout [fixed]
CH_NL
Post by CH_NL »
Hi there,
I learned that I can export the dmx addres list to a txt file. What would be helpfull is to do the same for the grit lay out (e.g. the position of the fixtures in the grit). Is there a way to print the layout of the grit including the position of all the fixtures?
thx
CH_NL
Re: Print Grit layout
The file "home_directory/YourLightShow/3DView/fixtures.ini" may be interesting for you.
CH_NL
Post by CH_NL »
Thx for the response. Since this is an ini file, I wouldn't know how to print this. Any ideas?
CH_NL
JohnRichards
Post by JohnRichards »
Open it in Notepad or any other text editor and print
CH_NL
Post by CH_NL »
Works like a charm. Together with a top view print of the 3d view (with fixtures in color) this should be sufficient to send to the theatre technician, so he/she can build up the rig in advance. Cheers mate.
CH_NL
