Problem with Pucks in 3D view...beams stay white [fixed]
TMC Entertainment
Post by TMC Entertainment »
I'm new to this forum, still trying to find my way around ShowXpress...for some reason, I stumbled across this issue:
When in 3D view, my pucks only show a white beam (when in 6 channel mode), I can only get them to dim & strobe...can't see a visual on the 3d viewer with RGB.
Now, when I put my pucks in 3 channel mode on the board, I am able to see the colors changing on the 3D viewer.
Can someone help me out please.
Very much appreciated.
-Vic
Re: Problem with Pucks in 3D view...beams stay white
Please tell the exact name of the personality files you are using.
TMC Entertainment
PUCK_RGB
Fixed the issue...changed over from par can to color changer in 3D view setup.
Thanks!
Yes, we still use the name "parcan" for the good old original par can (no led) which can beam one single color.
So we use the name "color changer" for non moving lights able to beam different colors.
