Timeline is ready
Timeline is ready
Timeline is ready
The biggest news is Timeline is ready.
Right now, we propose only the Windows beta version (sorry for Mac users). The MacOS version will follow in a few days. Please note that all bugs found in this version will be fixed for all operating systems.
Here is the changelog:
  • All - "pure" colors (red, blue yellow, ...) are nows listed in the file "../icons/colors.ini
    ControlBoard - becomes unique server for all applications (IP and ports) (except ScreenControl)
    ControlBoard - shows name of current light show in title bar
    Setup - auto refresh with groups changes from Editor
    Setup - 'edit level name' & 'add level' crash after changing channel fixed
    Setup - problem of saving current fixture when selecting another fixture
    Setup - problem when selecting "parcan" in section 3DView
    Setup - keyboard shortcuts (Windows only)
    -- crtl + a : select all dmx addressing
    -- crtl + shift + a : select all dmx addressing from same model
    -- esc : exit and close child window without saving
    -- tab : control entered min&max level values and change gadget focus (Windows only)
    Editor - possibility to select (red mark) more than 256 channels
    Editor - improved listbox of groups with popup menu
    Editor - "grouped/non grouped action" function in tab "Group"
    Editor - correct screen refresh with snap transtions, in "play" mode
    Editor - in tab "All channels", in a multi channels selection (red mark), one slider moves the whole selection
    Editor - "file -> delete" function
    Editor - shows the selected group (with keyboard), in the list of groups
    Editor - auto refresh the channels after a change in Setup
    Editor - shows name of current scene in title bar
    Generator - "project -> delete" and "curve -> delete" function
    Generator - "curve -> move" and "curve -> size" are in one single menu
    Generator - shows name of current project in title bar
    2DView - auto refresh the background export from 3DView
    2DView - size of fixtures icons is correctly saved
    2DView - tooltips for fixtures
    Live - shortcut keyboard key for flash buttons works
    Live - chase/random page play bug fixed
    Live - non flash buttons start at "mouse up" event, instead of "mouse down" event
    Live - a keyboard shortcut can trigger a flash button
    Live - a keyboard shortcut can trigger more than one button
    TimeLine - is included as a tab into Live
    3DView - auto refresh fixtures changes in Setup
    3DView - MacOS - shows the selected object in windows "Object settings"
    3DView - status bar which shows FPS (Frame Per Second) and # of faces (stage file size)
    3DView - icons for popup menus
    3DView - clone fixtures respond
    interface Cable - channels 2, 3, 4, 5, 6, ... were driving dmx outputs 1, 2, 3, 4, 5, ... - fixed
Version 6.20 beta1 is available here: http://download.thelightingcontroller.c ... ware/beta/
Please make a backup of your lightshows before trying this version.
Please make posts regarding 6.20beta1 exclusively in this section (6.20 beta1).
Return to “6.20 beta”
