beta5 - 30 Mai 2012
New program 'Pixels' for RGB fixtures
beta5 - 30 Mai 2012
The main news are:
- midi sliders to dmx outputs patch
- Pixels with built-in bank of fixtures
Here is the complete changelog since version 6.29:
- ControlBoard - higher dmx frequency (better for LEDs) (not suitable for old Box & Ssa interfaces)
- ControlBoard - patch Midi (note/control/program change slider/wheel) to dmx outputs
- Setup - saves 2DView image in profile
- Setup - popup menu in "list of private fixtures" in "Fixtures setting"
- Setup - crash sometimes, after long period using icons windows, fixed
- Editor - color wheel works with CMY channels
- Editor - respects the transparent background of "level" icons
- Generator - was crashing if curve "default" is missing
- Pixels - bank of fixtures
- Pixels - quick "mouse addressing" in "Fixtures properties"
- Pixels - listview for effects, with select/edit and popup menu ability
- Pixels - dimmer & saturation adjustable curve in "File > Properties"
- Pixels - "white" lamps (non RGB) management
- Pixels - GIF files to pixels
- Pixels - smart auto addressing with copy/paste fixtures
- Pixels - live view in dmx outputs of changes in "Fixture properties"
- Live - MacOS - problem with trigger keyboard key "q" fixed
- Live - MacOS - problem to open "Move button" window fixed
- Live - MacOS - "Buttons#2" was losing focus after clicking on a button
Version 6.30beta5 is available here: http://download.thelightingcontroller.c ... ware/beta/
Please add also the file "fix_for_MacOS/Windows.zip", which contains a fix for following bug:
- 3DView does not show the fixtures&objects
Return to “6.30 beta”
