Pixel Programming (Pix Par 12 & Pix Par24)
rbekel
Post by rbekel »
Does anyone understand the pixel programming? I understand Pix Par12 is now shipping to dealers. Is there any other information about programming pixels like a video or more printed information than the 4 pages that has been released to date? I have some on order and need to get them programmed in about 2 weeks time. I have a copy of the manual I downloaded but not much help there. Any Ideas?
Allan
Re: Pixel Programming (Pix Par 12 & Pix Par24)
Post by Allan »
What exactly are you trying to do? Program the individual pixels using ShowXpress or trigger the built-in programs via ShowXpress?
Allan Reiss
Senior Product Manager
CHAUVET DJ
rbekel
Post by rbekel »
I'm trying to understand the Pixels portion of ShowXpress and how to use it.
bsurfing
Post by bsurfing »
Rbekel, were you able to find any new documentation on Chauvet Showxpress pixel programming? I am trying to program it with a ADJ Revo 4 light which has 256 pixels where each individual pixel is on a channel. There are inumerous possibilities but without knowing how to configure it properly it doesn't do much except load animated gifs or chaser/rainbow pre-programmed effects.
It is presently possible to layer, "chaser", "rainbow" and "GIF anim" effects.
http://www.youtube.com/watch?v=gVxBLqFFfgU
In a short time, a new effect called "Picture motion" will be added.
bsurfing
Post by bsurfing »
Hi Support, thanks for the info. ShowXpress won't let me create more than 100 channels for a light. Revo4 has 256 LEDs and each should be in a channel to allow proper programming, right? But when I get to channel #100 and tries adding one more ShowXpress resets the count and erases all. How can I setup 256 channels for a light? Thanks again.
The fixtures for Pixels must be created from Pixels (not from Setup).
- right click in the grid and select "Add Fixture"
- click upper left on icon "Open" and find your fixture
- if your fixture is not in the bank, create it in the "Fixture properties" window
rbekel
Post by rbekel »
After you create the fixture in the pixels section, how do you save it and make the grid look like the fixture properties grid?
I'm working on a pix par 12 (36 ch)
Click on the upper left button "Export fixture", to save the fixture.
Sorry but, we do not understand the second question.
Return to “Pixels”
