Once I import the scene for the live show, and I click it on it, making it grey shade, also have the 3d button in green; but the no visual of the show in the 3d window. I play the same scene in the setup window and the show works fine. Am I missing a step to setup the live show?
This is on Windows 7 64 Bit if it helps.
Live Show [fixed]
Re: Live Show
Is the BUILDER 3D button off or on when you are running a scene from LIVE with it's 3D button on?
Depending on what you are doing and what channels you have activated when you have both 3D's the program has to make a priority choice of what to do, therefore, show you in the 3D VIEW window.
ashley.saylor@facebook.com
http://projectpinkband.com/
http://johnnywadband.com
Re: Live Show
With the Live panel 3D Button on and the 3D window only, the show still does not play, nor does anything happen in the DMX window.
Re: Live Show
I am sorry I said BUILDER instead of EDITOR but I take it you got what I meant.
However you did say you imported a show:
Did you go to Settings and in the LIGHT SHOW section, pick your imported show from the drop-down menu and then click on the "New Show" button?
If you did all that did you then close the CONTROL BOARD and start it again?
Hopefully that is your problem and I'll quote support from a thread about 3D VIEWER that may be of help to you:
Cheers!support wrote:There is effectively a problem ; we are working on it.
In the meantime, there is a workaround: each time you change the light show, you must close ControlBoard and restart it. Then 3DView should display the correct light show.
Re: Live Show
I got it, my mistake was I created another folder outside of the lighting Controller folder for my scenes.
Re: Live Show
Problem solved? Good!
