Live band use [moved]
Matthewclay
Post by Matthewclay »
Im using the software for my band sinked via midi using tracks. I play a lot of different size venues, & was wondering if there was a way to make some sort of zones & be able to change those zones to fit the size of stage im at? I have about 400 scenes so its impossible to change them right before the show. Any help would be awesome.
I have 6 moving head led lights in the backstage & 4 led par 64s in the front of the stage.
marco
Re: LIVE BAND USE
Post by marco »
Hi
Do you use combined scenes?
Combined scene is movement,color,dimmer,gobo in 1 scene?
Or do you use 1scene for movement and focus, a 2nd scene for color, a 3rd for gobo?
For making the scene i combine the 3 in live
On a show i adjust the different movement (i use about 15) but remember to save them under a diffentname
The org movement is on other sides useble sometimes, the amont of movement scenes growes everytime
Mij other scene dont need to change
If u upload your show i can look at it and give some hints
Grz marco
Matthewclay
Re: LIVE BAND USE
I dont combine my scenes like that. Could you explain that to me a little more in detail, I have about 400 scenes that I use, is there a way to do that with my scenes? Thanks for any help!
marco
Re: LIVE BAND USE
Post by marco »
hi
i made an example
with 1 ledpar and 1 microspot
if you program like this Rememeber to start everytime with a clean scene, (putting faders aktive and on 0 makes scenes behave stange and not wanted)
See also:
viewtopic.php?f=31&t=383
viewtopic.php?f=11&t=637
have a look
example.zip
(13.78 KiB) Downloaded 951 times
marco
Re: LIVE BAND USE
Post by marco »
and a compleet show
