Page 2 of 2
Re: Novation Launchpad Mini works with QuickDMX? [done]
Posted: 17 November 2019, 19:22
Our software is able to send one specific "Data2" for each "On" and "Off" state, but the other parameters ("Device", "Channel", "Type" and "Data1") are same for both states.
If this midi device indeed requires 2 different midi channels for "On" and "Off" states, which is weird, then this is not possible.
@ TimH
Could you please confirm it is not possible to drive two different colors for the midi device button, by using the same midi channel ?
Posted: 17 November 2019, 21:38
by SeekLighting
To be completely honest I've never tried using two colours. I just press the buttons and use whatever the default colour/light settings are. When I go back to work tomorrow I can try have a play with it and see what I can do though.
Posted: 19 November 2019, 17:37
by Tarzan4711
thank you for your help.
for explanation. I have several colors for the lamps on the Midi board. red, green, yellow, blue, etc. when the lights are off, the buttons should light up in the colors. if I choose a color the bag should flash. then I can see immediately which color is on. It would be great if that works. Thank you
