Novation Launchpad Mini works with QuickDMX? [done]
Tarzan4711
Post by Tarzan4711 »
Can someone tell me if the Novation Launchpad Mini works with QuickDMX?
Re: Novation Launchpad Mini works with QuickDMX?
We did not test it, but our software is supposed to be ok with such midi surface controller.
Of course the feedback from somebody who has it would be welcome.
SeekLighting
Post by SeekLighting »
Yep all MIDI devices work. I have the Novation Launchpad mini. Can confirm it works just fine
Thank you for your feedback Tim.
Tarzan4711
Re: Novation Launchpad Mini works with QuickDMX? [done]
Unfortunately, the Launschpad doesn't work with me.
Under setting Midi stands with me
Status OK, Midi device LPMiniMK3, Device type Default
Now I go to Butten trigger - Midi
Midi in hook
Device 1, Channel 1, Type Control, Data 0, Control
when I press learn and press a key on the Midi Pad be Data nothing comes. Can anyone help me?
Tarzan4711
I do not know why, but now the keys are taught.
Is there also a possibility that the keys eg bink red?
Our software can return one midi message for each received midi message.
You have to check in the manual of the midi device, what midi values to return for that.
Tarzan4711
if I set the channel to 2 in MIDI OUT the button will always blink.
But I want that eg. with Data on = red flashes and with off = red fix
Is there a way to write something in LIVE.ini?
Please watch this for midi in and out settings: https://www.youtube.com/watch?v=7bykEKgb260
Tarzan4711
The video does not show the Launschpad mini.
To make the keys of a Launschpad mini blink, the channel must be set to 2.
Example If the button is OFF, the key on the Launschpad should show RED fix. Midi Out on Chanal 1 and Velocity Off =5
If I put the button on I need this setting
Midi Out Chanal 2 and Velocity On = 5
Is that possible?
