can`t use the buttons with dmx
Re: can`t use the buttons with dmx
Please send us your lightshow ; we will check it.
DHoude
Post by DHoude »
Did you close Editor before going into Live? I think Editor can take priority over Live, if DMX is on in the editor.
SoonerDj
Post by SoonerDj »
Having the same problem. Scenes work fine when triggered from the editor screen, but will not fire when added to the live screen. I tried closing the editor, and nothing changed.
1) Do you have right allowed "Live" in your Firewall ?
2) Are your scene files right located in "/your_home_directory/TheLightingController/LightShows/your_light_show/scenes" ?
SoonerDj
Post by SoonerDj »
1.) Not sure how to go about that
2.) Yes
SwedLight
Post by SwedLight »
I could use the scenes in another (identical) PC at another place.
But still no success with the first one. I will mail you later this evening.
Firewall is now off, but Sweetlight were allowed there anyway.
Regards
/Swede
SwedLight
Post by SwedLight »
I have now found the problem...
I tried to save and recall the scenes from:
"/your_home_directory/TheLightingController/LightShows/default/scenes/your_light_show/"
And now it works !!
BUT...
I can touch the touch screen to change scenes with no problems, but when I touch the same scene twice everything freezes. I cant do anything without restarting the computer...
The screen reacts as if everything is ok, but the last scene freezes (lights on but no movements).
I cant exit the program, The question if I really want to quoit comes up, but the program will not disappear when I click YES.
Even if I close the program by "ctrl-alt-del" I cant get the scenes to work again...
Even in editor mode nothing will work until I restart the computer.
regards
Swede
SwedLight
Post by SwedLight »
Funny.. (or not)
Now it works... last night it didnt, and one hour ago id did not either...
Now i have tried to provoke the program to lock itself, but it works as good as it should... =)
regards
Swede
SwedLight
Post by SwedLight »
Strange... Now it happened twice in a row (probably because I wrote that everything was ok).
...and now its OK again, have done everything exactly the same when I have restarted it.
Even stranger: Now one of the scenes froze by itself after a couple of minutes.
What I also have noticed is that "live" does not autostart and "maximizes" although I have
checked the boxes under "preferences". Last night it did both.
regards
Swede
JohnRichards
Post by JohnRichards »
I woulld definitely let someone look at, and test your computer.
Freezing like that is either, a memory error, processor overheating, power supply voltages, or just simply a virus.
Return to “Buttons”
