Can we change parcan color after dmx addressing ? [fixed]
marco
Post by marco »
hi
is it possible to set the color of a parcan after its been set in the dmxset adressing menu?
if got a show were the pars( 40pcs) hang on a celling and the colors of the par changes sometimes, it would be useful to set the color in the popup were u set the adres instead of removing all par and set everyting again with the declare parcolor in fixture setting.now i set all pars to white but it looks better with the correct color
could this be possible in the future?
grtz marco
Re: colors parcan
Effectively, for us, changing the color of a parcan is like you change it to another fixture, so you have to change the fixture in application Setup.
We understand the problem, but we do not see any easy solution for your problem. So we can not forecast any software change for that right now.
marco
Re: Can we change parcan color after dmx addressing ?
Post by marco »
with the output patch this problem is solved for me now
grz marco
Thank you for this remark.
pogjack
Re: Can we change parcan color after dmx addressing ? [fixed]
Post by pogjack »
If you are talking about having a parcan one channel set for a color. I am doing it right now. I turn it on in 3d view and the color I have specified shows as a beam. If i go to setup and fixture settings tab, 2nd column towards the bottom where you can select the color. I can change the color and select save fixture on the top menu bar, the par can color changes to what I have just selected automatically without even having to restart 3d or live mode.
Return to “Setup”
