Windows can't find dongle's drivers
Windows can't seem to find drivers for my Sweetlight driever when I plug it into USB port. It searches for drivers and then tries to install but fails
brooksyno3
Re: Windows can't find dongle's drivers
hi there
i had this problem but then realised
when installing click manually
go to your sweet light folder that should be in your 'c' drive under programs also the place where you installed the sweet light and there will be a folder called drivers.
in there is a driver for all interfaces. select the one that you have for example the USB one and then click next and should work fine for you..
windows for some reason don't look in that folder and sometimes have to do it your self.
hope this helps
chris
hope this helps
chris
Kind Reguards
____________________________
DJ Brooksy
Chris-brooks
DJ Brooksy
Chris-brooks
