Chauvet - Intimitador 100
monster125.401
I don't know if the profile is incorrect or if it's just not showing up correctly in 3D view but strobe, gobo1, and gobo2 functions are not working at all. all I Can get is a white light and x/y controll
Re: Intimitador 100
Monster125,
After looking into your issue, I did find a small error on the strobe channel (ch 2) and have fixed it on the attached file. I also modified ch 6 (gobo wheel rotation) to be a little more accurate than what it was. Something to note with this fixture is that the individual gobos do not rotate, but the entire gobo wheel does rotate. This gobo wheel rotation can be controlled by ch 6.
Since this fixture has a combined color/gobo wheel, you will not see the gobos in the 3D visualizer. This is not an issue of the software, but an issue with the profile that will take some time to fix. There are currently many profiles (for various fixtures) that all need to be updated and we are working slowly on fixing them all. Please note that this is a HUGE process and will take us a while to complete.
The attached profile should get you going. If you have any other questions, please don't hesitate to contact us.
Allan Reiss
Senior Product Manager
CHAUVET DJ
CHAUVET DJ
monster125.401
Re: Intimitador 100
Thank you for your reply Allan as well as the updated fixture. and yes i had noticed that several of even your own Chauvet lights had incorrect profiles atleast the entire Intimitador line had something faulty. But thank you and hopefully we'll see those updated profiles soon
monster125.401
Re: Intimitador 100
Also if i wanted to update the Gobos myself for the Intimitador 100 all i have to do is assign the correct gobos in setup and put them in the okfor3dviewing folder in the 3dview directory correct? and i know they are not all in the library so how would i go about creating my own .png files?
Re: Intimitador 100
See this page: viewtopic.php?f=13&t=498
Allan Reiss
CHAUVET DJ
CHAUVET DJ
monster125.401
Re: Intimitador 100
yes i've actually read that and now figured out how to set up all gobos. But is there anyway to create our own gobos? or perhaps is there an updated library? I'm just surprised that the library doesnt even include Chauvets own light gobos
Re: Chauvet - Intimitador 100
That is partially what we are working on. Stay tuned!
Allan Reiss
CHAUVET DJ
CHAUVET DJ
